Hello
Newbie question here
Vuescan DNG RAWs > LrC with NLP 2.4
When I import my DNG raw file into LrC the NLP Guide tells me to…
** After import, select all the files, and go to “file > plugin-in extras > Update Vuescan/Silverfast DNGs” - then follow any instructions it gives you. (This step ensures compatibility, and may not be necessary for all users depending on your scanner model, but is recommended).*
** If step 2 has gone correctly, you should see the profile in Lightroom showing as “Negative Lab v2.1”, and there should NOT be any kind of profile warnings.*
My question is, do I need to do this everytime I import files?
Or is the profile that is created (and now available in the LrC dropdown) the same profile that should be used for all Vuescan DNG files going forward
Apolgies if this is a silly question, I’m sure as I go along and begin to understand the process it will become clearer,
Thanks
