Negative.lua:742: Could not write photo for analysis
Hello, I can’t seem to find any info on the internet about this issue.
I scanned negatives on Epson v800 using Silverfast 8.8… 48bit HDR Raw & DNG. However when I open into Lightroom to begin conversion process, it goes half way before giving me this error. The plugin is in the same directory with other plugins. Has anyone else run into this issue?!
I assume you are on Windows? See other threads about needing to place the plugin in a directory that has full read/write access. Most plugins do not require that (because they aren’t doing photo analysis). Try placing the plugin in a simply, root level directory, like “C:\Plugins”.
