At times, NLP does not show the LUT selector on the second tab.
I get this with original files and with virtual copies as well as in Lr’s library and develop tabs.
Restarting Lightroom has not done any good.
The LUT and other settings I saved (when the LUT selector was still available) display correctly in the metadata.
Meanwhile, I found that he LUT selector only shows when “color” is selected - I wonder why.
Please note that LUTs are still selectable but irrelevant for b/w and “none” color model conversions.
Digitizer , did you find a solution for missing LUT selector ? Thanks in advance.
The explanation is given in the original post. I had found that
and
Please note that the current version of NLP might have changed this pattern of hiding the selector - or showing it, although LUTs aren’t doing anything under certain circumstances that could also be taken into account for hiding the selector.
I’m not going to test this anytime soon though, but if you discover that the pattern has changed or still exists, you’re welcome to add another post to this thread.
