Thought this should be its own thread.
EDIT later: Post 2 and especially post 15 in this thread have more thorough personal analysis from me and serious explanations from another author, respectively.
Digital camera: Panasonic Lumix S1R - f6.9, 1/60th, ISO 100, Sigma 70mm ART.
Holders and Stand: Film in a Valoi 360 with their CS_Lite and light enhancing sheets. All on a Besseler 23C XL III enlarger turned into a copy stand. Took 4-5 tries for optimal focus and alignment (I was trying to be particular and kept bumping things). Best image pair used below.
Film Camera: water-resistant Nikon Action Touch (same camera as L35AW) with a 35mm f2.8 lens, automatic focus, automatic exposure. I selected this image because it was on hand, relatively sharp, and a decent photo that had good grain with limited whites and blacks.
Film: TMax 400, lab developed and scanned. Taken midday under cloudy conditions, early summer 2020.
Pixelshift mode set to also record a single, standard raw file on a 4 second delay trigger from the Lumix Tether software so I didn’t introduce shake. Mechanical shutter, which required me to touch the camera, also introduced shutter shock and so I did not include it. Panasonic outputs same 14 bit file in both E and M shutter modes. Interesting note, a single capture e-shutter image was 25% smaller than the E-Shutter single image + Pixel Shift combo. (~66mb vs 88mb). I used the larger E-shutter image instead.
I made a basic custom linear color profile (gamma = 1… I think?) and inverted using curves with some clipping applied to get it relatively pleasing and did screenshots for speed here. No sharpening, calibration, or anything else beyond white balance and curve was done.
Chose B&W film to show grain easily and color noise in single capture vs none in pixel shift. Did NOT desaturate or switch to Grey Gamma/B&W mode.
Base image comparison, Pixel shift (L) vs E-Shutter single (R):
Left Edge 300/600% crop to see grain / pixels / color noise comparison:
Near Center 400/800% crop to see grain / pixels / color noise comparison:
Look above for yourselves at how the grain, details, color noise and histograms relatively change (or don’t enough for some people).
Now for lab scan comparisons, which I think are of limited utility because so many variables and choices are made by me and by the lab. But some may want to know.
Pixel Shift vs the Lab Scan from back then (not edited to match, but scaled down to match lab scan size). I think I could very easily get them to match.
Pixel Shift Vs Lab scan edited similarly but not exactly. I could keep punching it up but I want to go make dinner!
EDIT added 2 days later: more images below in this thread Pixel Shift vs Regular Capture - quick comparison w S1R - #8 by SSelvidge
Cheers y’all
