I started scanning with my Fujifilm X-A7 and it looks like the profile for that camera is missing. Happy to send a raw file if needed!
After some testing, the X-A5 profile seems to work fine (these 2 cameras are probably using the same sensor) let me know if I can help @nate !
Hi @williambout,
I’ve added the X-A7 to the dropbox folder for new profiles:
https://www.dropbox.com/scl/fo/vb75ada233wqefpqz9lqa/AE8Fr_sqv9QO53ohC3_rZU4?rlkey=j6nlo5uih5ce55xsk6k0zwdjw&dl=0
You can download the x-a7 profile here.
Just download the profile, then go to “file > import develop presets and profiles” in LrC and add the file there.
Important note: Adding the profile may impact the appearance of negatives you converted previously (while the profiles were missing). This is because once the profiles are available, Lightroom will then correct apply the profile, but because the profile wasn’t there during the analysis, there will now be a mismatch between the analysis and the profiled image.
To fix this, you have two options:
- Re-convert the image. You can do this by opening the image in Negative Lab Pro, going to the “Convert” tab and selecting “Un-convert.” You can then convert and it will then be properly profiled.
- If you don’t want to reconvert previously converted images, you can make them appear as they did before by manually setting the profile to “Adobe Standard” (which is the profile it was likely using while the correct profile was missing).
