I have found that using Negative Lab Pro that the red eye feature of light room causes the problem to made worse. What is the solution for this?
Thanks
Hi @lubber,
The red eye feature won’t work directly on the negative because Lightroom is evaluating the original negative file (not the converted file). To get the red eye feature to work, you’ll need to make a “positive copy” and then all of Lightroom’s features will operate as expected. You can learn more here in guide about tips and tricks in Lightroom: https://www.negativelabpro.com/guide/lightroom
Cheers!
Thanks I didn’t know that you had replied. As I am processing many photos in batches I have not found a way to do that. I am hoping that when I finish and export all of my photos I can then do as suggest and reimport the affected images for that purpose. I somehow will need to keep track of them
