Greetings, I do not use roll analysis because it has never really worked for me. Today I thought I would give it another shot and found out the hard way that any variance in scanning exposure will completely throw off the resulting conversion. Here are two photos scanned with DSLR, the only difference being 1 stop of additional exposure when scanning due the the density of the negative. Every single photo I scanned with the additional stop of light has this green tint. I have never run into this before when converting without roll analysis.
Most frustrating is that the green tint persists even after reverting all settings and reconverting with roll analysis turned off. I know this is an issue with NLP and not with the negative itself as they convert fine in other programs. I am running NLP 3.1.1 on mac.
Thanks @Digitizer removing the files from LR and re-importing resolved this problem. I do not understand why it was persistent even after undoing all edits/NLP masks from the original files. A simple unconvert/reconvert came out exactly the same.
This seems like a glaring error in the roll analysis function. It’s not uncommon to have to change exposure settings to absorb more light through denser frames.
For persistence…I came across it using NLP v3.1.1 but not right from the start. My guess is that
updates of either macOS or LrC introduced the issue or made it visible, it’s built into NLP. Depending how good LrC UI actions sync into NLP, we could get the effect as described.
Undoing edits of NLP requires undoing (resetting) in NLP. After all, NLP is a plug-in to LrC, not the other way 'round
