I am a new user and wish to avoid as many problems as I can. I’ve read the guide and scanned the forum topics, but did not run across this particular question I have (or I may have missed it instead).
Question: I normally would use one of my user presets when importing a digital RAW image into LR. Should I do that for the capture of the negative? Or should I import as is, use NLP first, then do my tweaking in LR / PS?
By the way, if you’ve read this far, any suggestions on best setting to use in NLP beyond what is in the guide would of course be welcome.
In case it matters, I’m using:
Lightroom Classic CC
Sony A6300 with 35mm lens and a 16mm extension tube (I know, but I can’t afford the macro I want)
A custom camera scanning setup that I built.
The negatives are from the 70s and early 80s, probably either Kodak or Fuji
Thank you in advance,
Gary
