Hello,
I’m using Negative Lab Pro 2.2.0 and Lightroom Classic 10.0 on macOS Catalina. My usual method of processing a roll of B&W film is to select all 36 images, open Negative Lab Pro, convert to black and white, set the Tones to “LINEAR - Gamma”, click sync settings and then apply. LINEAR - Gamma is the base that I like to start with.
The problem I’m having is after I upgraded to Lightroom 10, Sync Settings seems to be broken. After clicking Sync Settings the images don’t look any different in Lightroom. As soon as I open one of them, however, the image is re-rendered correctly and I see the correct settings in the Negative Lab Pro control panel.
Am I doing something wrong or just found a bug? Anyone else seeing this?
Thanks!
