Bonjour à tous,
J’ai téléchargé “negative Lab Pro” pour essai il y a quelques mois. j’ai
voulu l’ouvrir il y a quelques jours et rien ne se passe pourtant je n’ai pas utilisé la possibilité des 12 photographies. Y a t’il une butée calendaire pour l’utilisation gratuite de “negative Lab Pro” ?
Merci par avance pour vos réponses.
Bien cordialement.
Translation:
Hello everyone,
A few months ago I downloaded “negative Lab Pro” to try. I wanted to open it a few days ago and nothing happens, however I did not use the 12 possible photographs. Is there a time limit for the free use of “negative Lab Pro”?
Thank you in advance for your answers.
Best regards.
You could a) check your installation or b) try with reinstalling NLP.
Check locations according to the install log:
Beginning installation of NegativeLab Pro for USERNAME
Installing custom camera profiles to
/Users/USERNAME/Library/Application Support/Adobe/CameraRaw/CameraProfiles/NegativeLab Camera Profiles/
Installing enhanced settings to
/Users/USERNAME/Library/Application Support/Adobe/CameraRaw/Settings/NLP Enhanced Settings/
/Users/USERNAME/Library/Application Support/Adobe/CameraRaw/CameraProfiles/Vuescan Profiles/
Setting up negative lab shortcut key [ctrl + n]
Adding shortcut key for Lightroom Classic CC
Adding Negative Lab Plugin to following directory:
/Users/USERNAME/Plugins
/Users/USERNAME/Library/Application Support/Adobe/Lightroom/Modules/
IMPORTANT INSTRUCTIONS
TO FINISH YOUR INSTALLATION
1) Restart Lightroom
2) Go to 'File -> Plugin-in Manager', then click the 'Add' button
3) Select 'NegativeLabPro.lrplugin' and click 'Add Plug-in'
(If you don't see it, navigate in the dialog box to this folder: /Users/USERNAME/Plugins/)
4) If you've already purchased Negative Lab Pro, add your license number and click 'ACTIVATE Negative Lab Pro'
(otherwise, you can take Negative Lab for a test drive in trial mode)
LEARN HOW TO USE: https://www.negativelabpro.com/guide
