Version 2.4.2 Custom Profiles
Is there a way to keep custom profile/lut when opening the NLP window to make adjustments? The profile jumps back to a pre selected NLP profile when I have my custom profile selected previously.
There is a way to do this. When you initially convert the negative, you need to have the “Color Model” set to 'None." Setting this to “None” means that Negative Lab Pro will not change any camera profile or enhanced profiles you have set. But just note that this also means that the Negative Lab Pro LUTs will not be available (since they rely on the Negative Lab Pro camera profiles).
