I am using Canon 5Dsr and 100mm macro lens, I am illuminating the negative with a modified flash studio strobe I put in a box and the negative is in Essential film holder. I cannot seem to make the curve any better than this and when i edit it so the whites and the blacks are filled, the final image is trully trash with artefacts and all. Can someone help? I am using Capture one and tethered shoot
Welcome to the forum @al_zemuni
If I understand your process, you do the following
- Capture negatives with camera tethered to Capture One
- Import captured image in Lightroom
- Apply NegativeLab Pro
If this is the case, then you could check a few things
- Does Capture One apply any preset or automatic adjustment on import?
→ Make C1 import images without any adjustments - Are the files RAW files? Or CRAW or compressed RAW?
→ Set your camera to write RAW files (not CRAW or compressed RAW of JPEG) - Does Lightroom apply any preset or automatic adjustment on import?
→ Make LrC import without any adjustments
