Just moved to a new pc (win 11 pro) from a win 10 pc. On the old pc, when I hit apply the file was automatically exported in LR to positives (sub)folder. The file is not exported on the new pc. All the settings in NLP appear to be the same. Is there something that I am missing?
If you want it to create positive copies by default, you can enable this in the “Adanced” tab when using Negative Lab Pro. In that same tab, you can also set up the default behavior for the file kind and location.
Thanks for the reply Nate, somehow without my changing settings in the advanced tab it has started to work! However, I did open the files from the library using all photographs instead of previous import.
