Windows Shortcut Ctrl-N stopped working
The Ctrl- N to launch NLP no longer works. Instead I get an option to save a new snapshot. I am using the latest version of LR Classic (August 2024) in Windows 11. I also tried Ctrl-alt-N. Nothing there.
First, the key combination for windows users will vary based on the language they have Lightroom set to… You can find list here: INSTALLING AND UPDATING | Negative Lab Pro
Make sure you are hitting and holding each key in the order it is shown.
If it previously worked and now no longer works, then try restarting your computer and see if that fixes it.
If that doesn’t help, you can re-run the installer and just select to install the hotkey.
You may also find in some instances that over-protective anti-virus software can prevent the hotkey from working, or in some cases, specific releases of Lightroom Classic could contain bugs that prevent it from working, so you can also try updating to the latest version of Lightroom Classic.
